This command configures a key to add to a keychain.
| keychain_name | Specifies the name of the keychain. |
| add | Specifies adding a key to the keychain. |
| key | Authentication key entry. |
| key_id | Specifies the unique identifier within a keychain. Range is 1-65535. |
| key-string | Specifies the shared secret text string for the key. |
| text_string | Specifies the string. Range is 1-127. |
| active-lifetime | Specifies the time period the key will be active. |
| local | Specifies the time in the local time zone instead of UTC. |
| start | Specifies the start of the time period. |
| start_time | Specifies the date and time the key will become active. Format is YYYY-MM-DDThh:mm:ss. |
| end | Specifies the end of the time period. |
| end_time | Specifies the date and time the key will stop being active. Format is YYYY-MM-DDThh:mm:ss. |
| duration | Specifies the length of time the key will be active. |
| seconds | Specifies the duration in seconds. Range is 1-15552000. |
| maximum | Specifies that the key will be active for 180 days from the start time. |
| encrypted | Specifies the key string in encrypted form. |
| encrypted_string | Specifies the encrypted string. |
N/A
A maximum of 8 keys can be added to a keychain.
The maximum length of a key string is 127 characters.
The maximum validity period of a key is 180 days.
The following command configures the keychain to add an OSPFv3 key:
create keychain ospfv3-keys1
The following command adds a key string to the keychain:
configure keychain ospfv3-keys1 add key 3 key-string auth3
The following command adds additional options to the keychain:
configure keychain ospfv3-keys1 add key 1 key-string auth1 active-lifetime local start 2021-06-01T00:00:00 end 2021-07-01T00:00:00
This command was first available in ExtremeXOS 31.3.
